1660318948285 Smfigure1positivetoleranceatshutoffexceedssystemdesign
Head Off Centrifugal Pump Problems
May 25, 2018
Attention to head tolerances can prevent poor performance and rework
The oil and gas industry heavily relies upon centrifugal pumps designed to meet API-610 specifications [1]. Familiarity with the pump head tolerances allowed under API-610 is necessary to avoid disappointment with the performance of the purchased pump and additional costs due to rework. These tolerances can result in significant deviation between the expected and actual performance for high-head pumps (e.g., injection or hydrocracker charge pumps). While API-610 provides many other specifications and tolerances, here we’ll focus on the tolerances related to the differential head at rated flow and maximum shutoff head.
As part of the procurement cycle, each potential pump vendor will recommend a particular unit and include a predicted performance curve. This performance curve demands careful evaluation to ensure the pump meets all specified requirements. During this review, the process engineer should check that the specified rated differential head requirement is met and that the maximum shutoff head doesn’t exceed any system limitations.
Performance Tolerances
Table 1. API 610 [1] considers these tolerances acceptable.
After the purchase order is awarded and the pump is built, conducting a certified performance test is sensible. The certified head at the rated flow and pump shutoff must meet the specified tolerances of the predicted performance described in the bid. Table 1 shows the allowable tolerances given in API-610.
Potential Problems
Let’s now look at two scenarios where the allowable rated and shutoff head tolerances could create unexpected rework and impact project schedule/costs. Brownfield/revamp work can be particularly susceptible to risks because the pump must be integrated into existing systems and the flexibility to modify those designs may be limited.
Scenario 1: Positive tolerance at pump shutoff exceeds system design pressure. The pump shutoff head typically is selected such that it won’t exceed design pressures of downstream systems. In certain revamp scenarios to avoid changing piping classes, rerating the piping/vessels or adding a pressure safety valve/high-integrity pressure protection system may be necessary to avoid exceeding design pressure. The proposed pump may be acceptable per the predicted shutoff head — but once the API-610 tolerances are applied, the actual shutoff head could be 5 to 10% higher. Figure 1 illustrates how the allowable positive tolerance at shutoff can cause a certified performance curve to exceed the design limits of an existing system.
In this scenario, the pump impeller would need to be retrimmed and the pump retested to ensure the system design limits aren’t exceeded. This also may impact the rated performance and feasibility of the selected pump.
Shutoff Head Concern
Figure 1. Positive tolerance at shutoff may lead to head that exceeds system design.
Scenario 2: Negative tolerance at rated point results in an underperforming pump. Without considering the allowable tolerances of the rated head, the performance of the preliminary curve may appear acceptable. However, a negative deviation of the rated head may lead to a pump that underperforms. For example, a high-head cavern injection pump may require a rated head of around 2,500 m. API-610 allows a tolerance of ±3% of the rated head. If the certified pump has rated head 3% less than the predicted curve, then the pump could lose up to 75 m of developed head. In typical liquefied-petroleum-gas service, this can result in a loss of up to 370 kPa of developed head, which may be significant. The process engineer should consider the potential for reduced head and determine if the system has sufficient hydraulic capacity to absorb deviations between the predicted and certified performance. Figure 2 illustrates how the allowable negative tolerance at the rated point can cause a certified performance curve to fail to meet pressure requirements.
If the system lacks sufficient hydraulic capacity, the pump impeller either would need to be replaced and retested, or a reduced flow may need to be accepted. However, depending upon the design limitations of the system, replacing the impeller to gain head could lead to exceeding the system’s design pressure at pump shutoff.
Inadequate Head Issue
Figure 2. Negative tolerance at rated flow may mean pump doesn’t provide sufficient head.
In either scenario, unexpected modifications to impellers and retesting can create additional costs and impact schedule. Pump disassembly and impeller trimming or recasting could be a lengthy process depending upon the size and style of pump. For example, large high-head multistage pumps would take longer to modify. The pump purchaser will bear the costs associated with the required impeller modifications and retesting along with any schedule delays if restrictions on API-610 tolerances weren’t specified and agreed upon earlier in the procurement process.
In the worst case, an impeller modification may not allow the selected pump to meet the required conditions; this either would result in accepting a derated performance or switching to a different pump. If a different pump is necessary, the new procurement process would further delay the project.
Heed This Heads-Up
Understanding the tolerances allowed under API-610 with regard to pump shutoff head and rated differential head can avoid costly rework and schedule delays. When specifying the required performance of a pump, the process engineer should identify any potential issues with API-610 allowable tolerances on pump performance and include a note on the datasheet that restricts the tolerances. By determining early on in the procurement cycle that full API tolerances aren’t acceptable, the process engineer can help minimize risks to schedule and cost.
JONATHAN R. WEBBER, P.E., is a process engineer for Fluor Canada Ltd., Calgary, AB. DUNCAN J. BLAIKIE, P.E., and THERESA R. WINSLOW, P.E., are process engineers for Fluor Canada Ltd., Saint John, NB. Email them at [email protected], [email protected] and [email protected].
ACKNOWLEDGMENTS
The authors thank Jeff McKay, lead mechanical engineer for Fluor at Irving Oil, for reviewing our draft. It was developed under the Fluor Calgary office Professional Publications & Presentations Program (P4), a mentorship program that encourages and assists first-time authors interested in developing publications.
REFERENCE
1. “Centrifugal Pumps for Petroleum, Petrochemical and Natural Gas Industries,” API Standard 610, 11th Ed., Amer. Petroleum Inst., Washington, DC (2010).
