The Model 20 HT/GT top-entering agitators feature a swing out seal change design for easy seal maintenance and reduced maintenance cost. With these agitators, there is reportedly no need to lift or remove the gearbox, saving labor and downtime. For replacement of the mechanical seal, simply rotate the gearbox 90° around the pivot pin. The top of the seal pedestal opens for a clear, line-of-sight view and ample room for easy removal of the coupling half and seal assembly. The agitators also have a modular design package that reduces the number of replacement parts that need to be carried in inventory.
Chemineer; (800) 643-0641; www.chemineer.com
Weight Controllers Include Network Communications
Only three inches deep, the HI 4050 general-purpose weight controller is now available with Allen-Bradley Remote I/O (RIO) network communications. The HI 4050 RIO interface is a direct replacement for the HI 2151/30WC and HI 2110WI weighing instruments with RIO, as well as some competitors’ weighing instruments with RIO. The weight controller includes Waversaver to eliminate the effects of surrounding vibration for fast, stable weight display, C2 electronic calibration without test weights, a Secure Digital (SD) based Secure Memory Module card for fast transfer of configuration data, and Integrated Technician for system diagnostics and troubleshooting.
Hardy Instruments ; (800) 821-5831; www.hardyinstruments.com
Software Enables Sharing Schematics Throughout Plant
OpenPlant PowerPID software for process and instrumentation diagrams is based on a completely open data model. The data are stored and maintained in a neutral, nonproprietary format that can be accessed by any application that is mapped to the ISO 15926 schema. So, any data that are mapped to the ISO 15926 schema can natively interoperate with OpenPlant PowerPID. This means that any plant schematics created with the software can be shared without application programming interfaces.
Bentley Systems; (800) BENTLEY; www.bentley.com
Tubing Extends Heat Exchanger Life
