Wireless Transmitter
Figure 1. Leak detection system relies on discrete wireless transmitters to send data from sensors and sensor cables that detect xylene and benzene.
The leak detection project saved around 60% compared to a conventional wired approach. Moreover, the system took only one day to commission. Besides ensuring compliance with regulations, the installation has enabled the plant to expand the operators’ view and has enhanced its existing leak-detection practices, helping to improve site safety.
Project Challenges
The main triggers for implementing real-time leak detection were the flammable nature of the product itself and the desire to reduce compliance issues, increase employee safety and provide constant monitoring of the plant’s condition. There were some obvious challenges:
• difficulty in detecting/monitoring hydrocarbon leaks around tanks, valves and pipe flanges;
• absence of installed instruments on tanks to detect abnormal changes in level due to leaks;
• fluctuation of tank level with changes in process demand; and
• lack of ready-to-use options to detect leaks at valves and flanges.
The plant’s management wanted to avoid the issues posed by traditional wired online monitoring, e.g., requirements for extensive cabling, together with the associated input/output, signal converters and installation costs. So, an evaluation team began a search to select the right supplier and technology. It reviewed different vendors and then tested a number of potentially viable available options:
• gas detection using a catalytic probe;
• an optical monitoring system (spectral analysis);
• an analyzer for lower explosion limit (LEL) detection;
• WirelessHART hydrocarbon leak detection; or
• WirelessHART fast fuel sensors for leak detection.
The team found most promising an approach that integrated sensors that detect liquid hydrocarbons with WirelessHART communications technology. It put that option through further laboratory trials with simulated leaks. Successful test results prompted a decision to implement that approach at the plant.
