While there are endless choices in fluid measurement equipment, the very nature of the processes can place limitations on the feasibility of certain technologies. For instance, in highly corrosive or dirty liquids, the use of an insertion style plastic flow sensor with moving parts can create costly damage to the entire process system if a component fails. Reversely, some highly adaptable sensors, such as full-bore devices can dramatically increase installation and replacement costs as entire sections of pipe must be cut, causing significant process downtime.
So what is the optimum choice? This article will outline why the new Signet 2551 Insertion Magmeter is recharging the fluid measurement industry with numerous compelling reasons that differentiate it as the sensor of choice.
Known as the "Paddlewheel Company," George Fischer Signet revolutionized the process industry when it introduced the first industrial Rotor-X paddlewheel flow sensor more than 40 years ago. And while the paddlewheel is still a viable, low-cost solution for many common flow measurement applications, there are instances when its inherent moving parts can impair its performance and service life, depending on the fluid conditions and other process factors.
Electromagnetic flow sensors, sometimes referred to as magmeters, work on the principle of Faraday’s Law of Electromagnetic Induction. This theory asserts that when a conductive fluid flows through a magnetic field, a voltage is produced which is proportional to the fluid’s velocity. There are no rotors or spinning turbines to wear out and no ports to get clogged by particles in the passing medium. Additionally, in the world of magmeters, there are two choices: insertion-style and full-bore, the latter mentioned earlier.
