Over the past few years the HART Communication Foundation and other organizations have worked in cooperation with automation system and device suppliers to produce enhancements to the Electronic Device Description Language (EDDL, IEC 61804-2). Phase One of the update process is now complete, specifications for the new enhanced EDDL have been submitted to the IEC for approval, and manufacturers have begun to implement the new EDDL.So, the question from users is: “Why should I care?” What does all this mean? What are EDDL, DDs or EDDs anyway?” The IEC Electronic Device Description Language specification refers to an all-encompassing specification with subsets dedicated to the specific protocols using the specification (HART, FF and PROFIBUS). Not all of the specification is implemented by each protocol, only the appropriate subset.Using Electronic Device Description Language, a DD or EDD is written and tokenized (similar to a compiling process) into a protocol specified binary encoded file, not an XML file. This encoded binary file is used by a host application to learn what features reside in a device. Because the DD is not an executable file it is unaffected by an operating system and will work on handhelds, PC-based programs, or asset management applications. “One DD to work everywhere.”The new enhancements correct a trend where DD-enabled host systems were getting away from the original intent of the language--to use one file per device to describe the resident features. Host system suppliers began to require device manufacturers to produce additional files or host specific DDs and to require additional testing of devices in order to use their DD. This meant that a device manufacturer might not support the host a user was implementing, keeping users guessing as to what was the correct DD for the device/host combination being used.The new enhanced EDDL specification promises to reduce the complexity and streamline the process for everyone involved. Host suppliers have agreed that no additional files or host specific DDs will be required which will improve quality assurance and interoperability of a device manufacturer’s DD across all host systems. Users will need only one DD for the version of the device they have installed and can be assured that if they get the DD from the HCF DD Library it is going work with their host.This is exciting news, but even more so is that EDDL provides new interface options. HART users will continue to see the original tree menu structure they have become accustomed to while allowing device manufacturers to describe new graphic “Windows like” menu structures making the setup of a device easier to understand. See Image 1.
