Comical Processing: You Write The Cartoon Caption Winner May 31, 2011
"Comical Processing" features drawings by award-winning cartoonist Jerry King. It’s our way of letting you take a break from all the serious stuff you deal with at work — by coming up with appropriate light-hearted captions.
Now I know why we designed the system with 60" inlet
ducts when the specs called for 12".
Honorable Mentions
"Management said that we were going to get a reliable leak detection system." Submitted by Jim Higginbotham; Chicago
"This is NOT what I was referring to when I said we are in 'Shut Down'!" Submitted by Ruth Ferguson
"Comfort test. Check." Submitted by Kevin Hanks
OTHER SUBMISSIONS
OTHER SUBMISSIONS
"Gee . . . I never knew the pipe contour fits human body so perfect. . . glad our HSE won't make any fuss out of this at least." Submitted by Girish Sathyanarayana; Singapore"Upph...how come this idea never struck me? Lemme try this in the other pipe." Submitted by Girish Sathyanarayana; Singapore
"ummm... I need to add one more item to the 'clean build' procedure check list – check for sleeping men in the pipe before steam out!" Submitted by Girish Sathyanarayana; Singapore
"If the boss sees this, you'll die in your sleep." Submitted by Cameron Watt
"Productivity is actually better when he sleeps." Submitted by Cameron Watt
"Now is a fine time to do your annual performance review." Submitted by Cameron Watt
"Enjoy your beauty sleep, you need it you ******!" Submitted by Cameron Watt
"I've seen a few men sleep on the job, but who in Hell brings a pillow?" Submitted by Cameron Watt
"...and me without a hammer." Submitted by Cameron Watt
"Did you check that the blind was installed first?" Submitted by Kenneth W. Russell; Alpharetta, Ga.
"This will not look good in my safety report." Submitted by Robert Andrew
"Larry, for as long as you've been gone you should have more than one 'Z' above you." Submitted by Harold Paine
"New cubicle design doubles as a cot." Submitted by Darryl Mote
"Frank, that is not an authorized sleeping place." Submitted by Mervin Archer
"Went the cheapest quote again, didn’t you Herb?" Submitted by Michael C. Piacenza; Murray Hill, N.J.
"He said your idea was a 'pipe dream.'" Submitted by Ashton Foster, Medina, Ohio
