Potential Raw Material
Figure 1. Well-defined transition metal complexes of nitrous oxide (color overlays) may foster its use in chemical reactions. Source: University of Warwick.
So, instead, the team built upon earlier work by chemists at Indiana University, Bloomington, Ind., and the University of North Carolina, Chapel Hill, N.C., — and its own in-house studies — which used cationic phosphine-based pincer complexes of rhodium as a platform for studying the coordination chemistry of nitrous oxide (Figure 1).
Rhodium is one of the most widely employed transition metals in organic synthesis; advanced analysis techniques enabled the team to identify and characterize its coordination with nitrous oxide in two separate pincer complexes.
“The compounds that we have prepared represent the starting point of our journey, but the associated experimental data seems to be guiding us in the right direction and we are looking forward to where it takes us,” notes Chaplin.
The next step is to explore the onward reactivity of such adducts in the context of catalytic applications.
The potential industrial application of the work will hinge on the chemical robustness of the catalyst. “In our case, we have used chelating pincer ligands, which are noted for conferring such stability, so that is promising,” says Chaplin.
Eventually, he believes, the work could generate new routes to fine chemical synthesis, along with bespoke oxidation reactions.
