Potential Low-Priority Substances
Table 2. The EPA has begun prioritization process for 20 chemicals that could be deemed low- priority substance candidates.
Discussion
As required by TSCA Section 6(b) and consistent with the prioritization screening review procedure, the EPA must undertake a process, including requesting public comment, leading to the designation of at least 20 high- and 20 low-priority chemicals for risk evaluation. This process must be completed by December 2019. The March 21, 2019, notice initiates this process; interested persons have until June 19, 2019 to comment.
The list of chemicals suggested for high-priority consist of several groups of related chemicals (eight halogenated organics, including two dichlorobenzenes, three dichloroethanes, a dibromoethane, a dichloropropane, and a dichloroethylene, and five phthalates) and seven other chemicals, including three flame retardants (both halogenated and non-halogenated), two chemicals used largely as chemical intermediates (butadiene and phthalic anhydride), a fragrance ingredient, and formaldehyde. None of the chemicals selected is particularly surprising. Similarly, the low-priority candidates merit review and EPA’s selection of low hazard substances should make the process easier.
Stakeholders with interests in these chemical substances need to engage and appreciate the significant implications of the EPA’s review. The high-priority chemical evaluations will almost certainly result in risk mitigation measures of some sort that will have commercial and market access implications. Similarly, EPA’s review of low-priority substances will not go unnoticed. It’s imperative that stakeholders engage and ensure the EPA is provided the best and most current information to assist in the risk evaluation process.
