Pulp And Paper Processes
Figure 1. Reducing consumption by Europe’s fourth biggest energy user could play a big role in the continent’s transition to a low-carbon economy. Source: European Commission Joint Research Centre.
Other BATs for mechanical pulping include high-efficiency grinding, enzymatic pre-treatment and improvements in chemi-thermo-mechanical pulping and thermo-pulping but, as the study notes, “These opportunities are associated with higher investment costs.”
Moisture is a costly issue in pulp and paper processing. The study says significant energy reduction here is possible with more efficient water-removal devices and new drying technologies such as boost drying and microwave drying.
Combined heat and power (CHP) systems also fall under the study’s spotlight. Although the sector is one of the highest adopters of CHP power in the EU (accounting for around 10% of total capacity in Europe), the availability and cost of natural gas and long-term system reliability are important determining factors in its uptake. While capital investment is high, payback in a large mill could only take about three years, the report states.
The JRC also considers a number of new technologies, including biorefineries and two emerging processes — black liquor gasification (BLG) and LignoBoost.
The report predicts biorefineries will bring significant technological, economic and social advantages to the industry because of their versatility: “Different biorefinery pathways, utilizing biomass as raw material, can be applied to the pulp and paper sector by integration of new technologies such as BLG, biomass gasification, lignin/hemicellulose production and processing/synthesis units, to provide a wide range of pulp, paper, energy, fuel and chemical products using biomass as feedstock. Possible feedstocks include wood extract, spent black liquor, forest biomass, agro-lignocellulosic products and sludge.”
For its part, BLG helps obtain energy more efficiently from the organic content in the black liquor through gasification, producing a combustible gas which after upgrading and conditioning results in a mixture of hydrogen and carbon monoxide known as syngas, while recovering the inorganic chemical. The BLG’s hot flue gases can generate steam in a boiler, resulting in high pressure steam for power generation in a steam turbine. “Alternatively, the syngas can be used as feedstock for production of biofuels such as dimethyl ether, Fisher-Tropsch (FT) fuel, methanol, etc., turning the paper mill into a ‘refinery’,” says the JRC.
Meanwhile, LignoBoost is an emerging technology that enables extraction of up to 25–50 % of the lignin from the kraft black liquor via precipitation at low pH using carbon dioxide and dewatering. The lignin then can serve in other profitable applications such as producing chemicals and materials including carbon fibers, activated carbon, phenols and other value-added products.
The study concludes that to make the most of these opportunities, the pulp and paper industry — and others — need EU policies that support research and innovation.
