CHANGE IN SHAPE
Figure 1. A trimmed impeller and a scaled down one boast different shapes.
Figure 1 shows that trimming an impeller alters both shape
and diameter. It depicts, from left to right, the original impeller, the impeller trimmed 10% of its diameter by cutting its end off, the impeller proportionally scaled down by 10%, and the trimmed impeller superimposed on the scaled impeller — with blue and green highlighting the differences.Normally, only the original pump manufacturer will have the data that allow for accurately predicting how impeller performance will change when trimmed. Applying the affinity law for diameter change provides an educated guess on the new pump head — but it's still only an estimate.Nonetheless, we can predict the general trend via pump specific speed,
NS, a parameter centrifugal pump manufacturers use in detailed pump design:
NS = N(Q)0.5/h0.75 (2)where
N is rotational speed in rpm,
Q is flow rate in gpm, and
h is head in ft. Specific speed is evaluated at the flow rate and head delivered at the pump's best efficiency point for that impeller. As long as dimensions are fully scaled, pumps with different size, but the same shape, impellers will have the same specific speed. This means that pump curve shifts due to impeller diameter changes can be predicted accurately.The most efficient pumps have specific speeds in the range of 2,000–3,000 rpm. Higher heads and lower flow rates shift pump selection toward lower specific speeds, and vice versa.
Figure 2 compares pump impeller shape versus specific speed. Low-specific-speed pumps have relatively little change in impeller shape when trimmed. In contrast, high-specific-speed pumps have dramatic changes in impeller shape when trimmed. Thus, the lower the pump specific speed, the less deviation there is from the affinity law when cutting the impeller diameter down.
