Transmitter sends corrosion data wirelessly
The Microcor Wireless Transmitter for high-speed communication of corrosion rate data integrates with Emersons Smart Wireless offerings. Corrosion information from the device is available for use in the automation system where it can be logged, trended and analyzed along with other process information. Corrosion data are also available in AMS Suite: Intelligent Device Manager software, used for device configuration, calibration, and documentation and predictive diagnostics. This extends the predictive diagnostics coverage of AMS Suite to corrosion, enabling a predictive approach by users that reduces maintenance costs, prevents unexpected shutdowns, and optimizes plant assets.
The VS Drive line includes two models of high-performance adjustable speed AC drives with powerful processors and advanced design features, three microdrive models offering a cost effective solution for basic adjustable speed applications, and a pump/fan drive designed to provide the control needed for maximizing energy savings without sacrificing functionality. Built on the H2 technology platform, the VS1SP sensorless vector drive and VS1GV closed-loop vector drive are high-performance variable speed AC drives designed to tackle difficult and demanding applications regardless of what voltage, power rating or performance level the application demands.
