- Home
Signet 8900 multi-parameter controller measures flow, pH, ORP, conductivity, pressure, level and temperature
The Signet 8900 multi-parameter controller takes the concept of modularity to the extreme. Each 8900 is field commissioned with the users specified combination of inputs, outputs, and relays using simple-to-install modular boards into the base unit.
