Hydraulic Institute Introduces Updated Standard For Rotary Pump Tests
Nov. 11, 2010
The Hydraulic Institute (HI) has updated the ANSI/HI Standard for Rotary Pump Tests version 2000, and has introduced ANSI/HI 3.6 – 2010, Rotary Pump Tests.  This updated standard applies to industrial/commercial rotary positive displacement pumps and includes detailed procedures on the set up and methods for conducting hydrostatic test and performance tests of such pumps.  ANSI/HI 3.6-2010 is immediately available for purchase through the HI online retail store, http://www.eStore.Pumps.org. Significant updates include complete reformatting of the standard to a one-column layout for easier reading; use of larger graphics and figures; more detailed descriptions.  Also included is an equation for pump output power.The new standard provides most current testing procedures and acceptable deviation of dependent test quantities from specified values for Type III and Type IV testing and is intended for use by all testing facilities.  The objective of ANSI/HI 3.6 - 2010 is to establish a uniform demonstration of a pump’s ability to perform satisfactorily both mechanically and hydraulically.A number of leading rotary pump manufacturers served on the committee that developed this standard, including: Flow Solutions Group, IMO Pump - Colfax, Intelliquip LLC, Leistritz Corporation, Milton Roy Americas, Moyno Inc., Roper Pump Company, Siemens Water Technologies, and Weir Floway, Inc.
