Motor Subtype I Efficiencies
Table 1. All such motors must meet NEMA Premium efficiency as specified in NEMA MG1, Table 12-12.
Source: NEMA MG 1-2009. Used with permission.Manufacturers of some designs of subtype-II 1–200-hp. and general-purpose 201–500-hp. motors may have to raise their efficiency; however, many designs may already comply. NEMA Premium efficient motors meet or exceed EISA requirements for either of these motor types.
Exclusions
EISA doesn't apply to fractional-hp. and 48- or 56-frame motors. It only covers 1–500-hp. motors with three-digit frame NEMA numbers (143T and up) or equivalent IEC designations of frames 90 and larger (excluding IEC100).
Not every three-phase 1–500-hp. motor configuration falls under EISA — but almost all motors except some special OEM designs with proprietary mounting configurations do. The following configurations are exempt from EISA compliance:
• single-phase motors;
• DC motors;
• totally enclosed non-ventilated and totally enclosed air-over enclosures;
• Design D with high slip;
• integral with gearing or brake where the motor can't be used separately;
• inverter duty motors with windings optimized for adjustable-speed-drive use that can't be line-started;
• Design D high-slip motors;
• customized OEM mounting;
• intermittent duty motors; and
• submersible motors.
EISA requires any custom motors included in OEM equipment that falls within the guidelines of the act to comply with efficiency levels for that type of motor. Each OEM should prepare for the changes well before December and develop designs immediately, particularly when UL or CSA approvals are required.
EISA makes no distinction for duty cycle rating. It's necessary to look at the EPAct definition of "electric motors" and "general purpose" to determine if a particular design falls under the requirements.
EISA also doesn't distinguish between stock and custom motors. The determining factor is whether a particular unit meets the law's definition of "electric motor."
EISA applies to motors imported into the U.S., including ones that are components of another piece of equipment. It doesn't apply to motors exported from the U.S., including ones mounted on equipment. These motors or their boxes must be specifically marked "Intended for Export." (Other countries are enacting their own minimum efficiency performance requirements for motors. Canada's version of EISA takes effect on January 1, 2011. Mexico's version likely will resemble the U.S. EISA, except it only will apply to stock motors sold through distribution and available to the public, not custom motors or motors orders by OEMs and users.)
EISA doesn't require replacement of motors in use. The law doesn't affect the repair of motors already in service. It also doesn't impact inventories — motors on hand as of December 19, 2010, can be sold or used as before the law.
