Chemical Processing's Editorial Board, which consists of technical professionals with diverse responsibilities and from a variety of industry sectors (see sidebar), evaluated 18 entries in 9 categories for technical significance, novelty or uniqueness, and breadth of applicability. This impartial panel didn't have to bestow any awards — but chose to honor five products:• Qdos30 metering pump from Watson-Marlow;• Elite CMFS Coriolis flow meter from Micro Motion;• Tigerflex Voltbuster hose from Kuriyama of America;• Process Innovator from Epcon International; and• EnviroSol 531 chemical cleaning process from Perigee Solutions.
Metering Pump Combines Better Performance with Less Maintenance
The Watson-Marlow Qdos 30 peristaltic pump, which was launched in June 2013, provides accurate, linear and repeatable metering under varying process conditions. The no-valve pump doesn't need recalibration because of changes in pressure, solids' content or viscosity. It will continue to pump even when a feed chemical is subject to off-gassing. Unlike traditional diaphragm metering pumps, for which it is a drop-in replacement, the Qdos 30 doesn't require ancillaries such as backpressure valves, degassing valves, pulsation dampener, foot valves and strainers. It can maintain accuracy and repeatability for up to six months without maintenance.
The Qdos 30 pump features the patented ReNu pump head, which is a fully contained tube-and-rotor assembly that can be replaced without tools and without risk of exposing operators to fluids. In addition, the pump head has an integral optical sensor to detect leaks in the fluid path.
The Qdos 30 pump can provide flow rates from 0.001 to 8 gal/h (0.1 to 500 mL/min) at 100 psi (7 bar). The unit includes a 3.5-inch full-color display that gives instant pump status, and is configurable to provide a wide variety of information, including percentage of chemical pumped from a discrete source and the amount remaining. The pump comes with various control options, including remote control for process security. The unit is NEMA 4X rated for washdown environments.
THE JUDGES
Vic Edwards, process safety consultant, Houston
Tim Frank, associate R&D director, Dow Chemical, Midland, Mich.
Ben Paterson, senior engineering advisor, Eli Lilly, Indianapolis
Roy Sanders, process safety consultant, Lake Charles, La.
Ellen Turner, tech service and application development rep, Eastman Chemical, Kingsport, Tenn.
Ben Weinstein, section head, chemical systems modeling and simulation, Procter & Gamble, West Chester, Ohio
Jon Worstell, consultant, Houston
Sheila Yang, principal engineer, Genentech, South San Francisco, Calif.
