USE OF THREE-WAY VALVE
Figure 2. Valve can be located upstream to split streams (V1a), or downstream to mix them (V1b).
Buying and installing one three-way valve typically will cost less than putting in two separate single-flow valves. Nevertheless, plants often avoid three-way valves.Historically, three-way valves generally were available with linear characteristics. So, systems needing equal-percentage or proportional characteristics weren't seen as good fits for the valves. Today, though, three-way valves come with linear, equal-percentage or proportional characteristics. They even can provide different characteristics for each path.However, existing plant layout may work against using a three-way valve. If a single-flow valve already is in place, adding a second one often is cheaper than installing a three-way valve and doing the necessary piping reconfiguration.In many systems, using a three-way valve creates a new common-mode failure case. Failure of the single three-way valve affects both E1 and E2. While failure of single-flow valves in parallel piping also causes interactions, the effects often are different. In some systems, the extra failure mode is relatively unimportant — for example, when a common failure mode already exists and contingency has been designed into the system. In other cases, addressing the new common-mode failure incurs extra expense to keep the plant safe.Other requirements such as tight shutoff and special startup, shutdown or minimum flow requirements also might make a three-way-valve application more difficult.Three-way valves are useful devices that deserve to be considered more often in process plants. However, you always should thoroughly check the possible implications of their use in an application.
ANDREW SLOLEY is a Chemical Processing contributing editor. You can e-mail him at [email protected].
