Figure 5. Integrated flow loop: This modular valve manifold offers a direct route to the analyzer, ensuring the same flow from all streams.
Specification Compatibility. A primary factor in size reduction of stream selection assemblies is the advent of the ANSI/ISA 76.00.02 specification for miniature and modular analytical systems. This specification, which grew out of the New Sampling/Sensor Initiative (NeSSI), calls for these systems to be surface-mounted onto a substrate featuring inlet and outlet connections contained within a 1.5-inch-square footprint. Compatible stream selection valves save installation and maintenance time because they can be quickly mounted directly to substrates. Systems that require additional tubing and connections to fit into ANSI/ISA 76.00.02 substrates may increase the system’s overall cost in materials, labor and maintenance, especially when reconfiguring an analytical system.
Fail-safe seal between actuator air and system fluid. It’s critical that a stream selector valve have a fail-safe means of ensuring that air from the actuator doesn’t leak into the system fluid, which is under pressure. Oxygen mixed with process fluid under pressure could result in combustion. A fail-safe design ensures that if one seal fails, another still performs the job or, if both fail, the air or fluid will vent to atmosphere or a collection area rather than mixing.
Visual actuation indicators. These make it easy to identify which stream selection valve is pneumatically actuated at a given time in the analytical process. They provide visual confirmation of the sample system’s operation and speed troubleshooting. Large, brightly colored indicators enhance the user’s ability to know that a valve is open.
Easy maintenance. By design, modular stream selection valve assemblies offer ease of installation and maintenance. Multiple valve modules and base blocks are connected to create the sampling system — each can be replaced without removing fluid connections. In addition, vertical disassembly of valve modules from base blocks simplifies maintenance and prevents accidental disassembly of a whole unit. Even small points in the mechanics of assembly, such as independent insert bolts that are captured within the base block, contribute to a system’s ease of use.
Click Image To Enlarge
