Figure 2. Subcooling should be impossible but may occur because of restricted flow from the condenser.
Figure 2 shows an exchanger mounted above the drum with a free-draining line into the drum. Normally, with gravity flow to drain liquid from the condenser to the drum we’d expect that subcooling is impossible. Yet this system has been shown to work. But how?
If its outlet nozzle doesn’t let enough liquid pass, the condenser can maintain a liquid level despite the piping layout for a gravity drain. Such flow limitations can stem from selecting too small a nozzle for the service or from restrictions, e.g., caused by buildup of corrosion products. As long as some liquid level remains on the tubes, it’s conceivable that the liquid leaving the exchanger could be subcooled. So, here, two mistakes balance out.
Or consider what can happen when using an air-fin exchanger as the condenser. Figure 3 shows an end-on view of liquid stratification inside the tubes in the air-fin. For wide-temperature-range condensing mixtures, low velocity in the tubes may lead to liquid separating from the vapor. Then external air may subcool the liquid on the bottom of the tubes. If mixing is limited in the air-fin header box, the liquid may enter the overhead drum subcooled. The same problem may occur if the air-fin has multiple tube passes. Phase separation in the header boxes may allow for some flooded tubes and some unflooded tubes in the exchanger.
