Occasionally an end user wants to take a motor designed for horizontal mounting and use it in a vertical position. This article addresses some of the key mechanical factors that should be considered when applying a horizontal ball-bearing motor in a vertical mounting position.
These key factors include:
Axial thrust load capacity of bearing supporting rotor weight
Rotor weight
Weight of output shaft attachments
Axial thrust from direct-connected driven equipment
Bearing lubrication paths
Bearing lubricant retention
Shaft up or shaft down orientation
Ingress protection
Locking axial thrust bearing
The first four factors above are inter-related because the weight of the rotor and any shaft attachments result in axial load on the fixed (thrust) bearing. Direct-connected driven equipment such as impellers or fan/blower blades can also impart axial thrust load on the fixed bearing.
