Preparing for Unloading
Figure 2. Arm supports the entire weight of hose, reducing the physical burden on operators.
“We’ve found the benefits to be exactly what we were looking for. It decluttered the work space and improved handling by the operators. They no longer have to lift and drag the unloading hose across the gangway to the railcar. Plus, the arm lowering and lifting mechanism by the railcar connection makes it easy for them to work around the fall protection cage,” Ohlhues explains. “One additional advantage we did not foresee was with the way the connection is made to the car. It removes stress on the hose crimped connection and railcar connection nozzle by being able to come straight off the top of the railcar with the hose being supported independently.”
Loading systems can optimize both safety and handling. They prevent torsion, bending and tensile loads. They increase the lifespan of hoses by eliminating damage from friction with the ground or from vehicles driving over them. More importantly, they reduce the physical burden on employees to a minimum, while making connecting hoses effortless and precise.
The systems are relatively modest in cost: Typical galvanized steel loading arms (without the optional height adjustment feature) that can handle 3-in. × 15-ft hose assemblies start at under $10,000, while stainless-steel versions cost a couple of thousand dollars more.
Widespread adoption of loading arms throughout the chemical industry almost certainly would reduce the number of PHMSA incident reports involving hoses in the loading/unloading process.
WILLIAM LESSER is global RS manager for Husky Corp., Pacific, Mo. Email him at [email protected].
REFERENCES
1. “Proposed Recommended Practices for Bulk Loading and Unloading of Hazardous Materials in Transportation,” Pipeline and Hazardous Materials Safety Administration, Washington, D.C., (2008)
2. “Incident Reports Database Search,” Pipeline and Hazardous Materials Safety Administration, Washington, D.C., (2017)
3. “Cargo Tank Motor Vehicle Loading/Unloading Operations: Recommended Best Practices Guide,” Pipeline and Hazardous Materials Safety Administration, Washington, D.C.
