Mechanically Induced Reaction
Figure 1. Initial components are placed in steel jar (left) to which a steel ball is added, and then undergo vigorous shaking, resulting in reaction products (right). Source: Kubota, K. et al. Science, December 19, 2019.
The process offers an alternative route to the one employed by the photoredox catalysts developed over the last ten years that use visible light to enable highly specific and efficient chemical reactions, the team notes.
Attention at the WPI-ICReDD now focuses on tuning the mechanically generated electric potentials. “The performance of our piezoelectric catalysis is still very low as an excess amount of the catalyst is required to achieve high reactivity. Design and creation of new piezoelectric catalysts should improve the reactivity as well as the tuneability of the mechanoredox reactions. We are currently working on this,” explains Kubota.
If this work succeeds, it could usher in new, low-cost, high-performance piezoelectric-catalysis-driven processes, he reckons.
Because of the mechanism of the reaction, these processes could replace most photoredox reactions currently in use, he adds. “We have already found other redox reactions using mechanoredox catalysis and will report in due course.”
However, another issue that still needs addressing is how to generate enough mechanical impact to activate piezoelectric catalysis on an industrial scale. “This is a potential challenge and careful optimization studies on mechanochemical parameters must be performed,” admits Kubota.
Nevertheless, the team already has started collaborative research with several companies to consider future industrial applications, he reveals.
