Reactor Inside View
Figure 1. This 12.5-m3 stirred vessel weighs 11 m.t. and is made from a corrosion resistant high-nickel alloy.
Two new multi-purpose production lines in the central organics pilot plant (ZeTO) are core elements of the current renovation and expansion activities. They have been specifically designed for producing large volumes of solids for the agrochemical and other industries. To this end, the production lines are being equipped with stirred-tank reactors with a capacity of up to 16 m3 (Figure 1). To make room, a number of smaller pieces of equipment have been dismantled. With the new reactors, ZeTO will have more than 70 stirred vessels.
A Nutsche filter/dryer (Figure 2) and a centrifuge/dryer combination are used to isolate the solid substances in the two lines. The high capacity centrifuge in particular eases isolating fine-grained agrochemical active ingredients and intermediates.
When it came to choosing the centrifuge and Nutsche filter, Saltigo opted for equipment made from Hastelloy, an extremely corrosion resistant nickel-based alloy, because an increasing number of agrochemical products contain fluorine and, thus, exhibit corrosive characteristics. While stainless steel equipment would have been significantly cheaper, it would have offered only limited corrosion resistance when manufacturing these kinds of products.
The ongoing investment project also will add an active container storage tank farm to the bulk storage options at the site. This will ensure more efficient supplies of raw materials and solvents to production in the ZeTO and the adjacent Plant 4. In addition, ISO tank containers stored there can be filled or emptied via a pipe junction connected directly to the production facilities. The plans include a reserve for further expansion of these storage capacities at a later date and for connecting more facilities.
The construction began in the summer of 2016, and work now is at a very advanced stage. The new facilities will be completed within the scheduled budget and timeframe. They will be ready for customer projects at the end of 2017.
