Shutterstock
bottom view of the distillation columns of the oil and gas industry
Energy Saver: Dividing Wall Columns Supercharge Distillation Efficiency
Jan. 17, 2025
This emerging technology promises up to 40% energy savings while reducing capital costs and carbon footprint in industrial chemical processes.
How Dividing Wall Columns Work
The fundamental innovation of DWC technology lies in its ability to overcome the thermodynamic inefficiencies inherent in conventional distillation sequences. In traditional configurations, the separation of multicomponent mixtures often results in what Segovia-Hernández (2018) term the "remixing effect" — where components concentrated in one column must undergo re-separation in subsequent columns, leading to significant energy penalties. DWC technology elegantly addresses this challenge through the strategic implementation of a vertical partition wall within a single column shell.
The evolution from conventional sequences to DWC configurations represents a significant advancement in process intensification (Figure 1). As demonstrated by Dejanović (2010), the integration of multiple separation steps into a single shell effectively eliminates the need for intermediate condensers and reboilers. This integration manifests in remarkable energy savings, with industrial implementations consistently demonstrating reductions in energy consumption between 20% and 40% compared to conventional arrangements.
The operational principle centers on the creation of distinct separation zones within the column. The feed section, typically located on one side of the dividing wall, facilitates the initial separation of light and heavy components. Simultaneously, the other side of the wall serves as a rectifying zone where middle-boiling components achieve concentration. This arrangement, as analyzed by Tututi-Avila (2014), enables the achievement of high-purity products while maintaining thermal efficiency.
Recent industrial implementations have demonstrated the versatility of DWC configurations. For instance, an extractive DWC implemented by Staak and Grützner (2017) achieved product purities exceeding 99% while reducing energy consumption by 30% compared to conventional arrangements. This success exemplifies the practical realization of theoretical advantages predicted in early research.
Engineering the Perfect Split: Key Design Parameters
The successful implementation of DWC technology demands a sophisticated understanding of multiple design parameters and their interactions. Buitimea-Cerón (2021) identify 12 critical design variables that must be carefully optimized, including column pressure, stage distribution and internal flow ratios. This complexity necessitates a systematic approach to design and optimization.
Central to effective DWC design is the proper sizing and placement of the dividing wall. Research by Czarnecki (2023) demonstrates that wall position significantly impacts both separation efficiency and energy consumption. Their analysis reveals that middle-wall configurations typically achieve optimal performance for systems with similar relative volatilities between components, showing energy savings of up to 14% compared to alternative wall placements.
The selection of operating conditions requires careful consideration of several interrelated factors. As documented by Lorenz (2018), successful DWC implementations typically align with specific criteria:
Feed Composition: The feed composition plays a crucial role in determining viability, with optimal performance observed when middle-boiling components constitute 60-70 mol% of the mixture. This finding, supported by extensive industrial data, helps explain why DWCs have found particular success in petrochemical applications where such compositions frequently occur.
Relative Volatility: The relative volatility relationship between components emerges as another critical factor. Segovia-Hernández (2018) indicate that similar relative volatilities between adjacent components favor DWC implementation, as this facilitates more uniform distribution of separation duties throughout the column.
Pressure: Pressure optimization represents a unique challenge in DWC design. Unlike conventional sequences where different columns can operate at independent pressures, DWCs require a single operating pressure suitable for all separations. This constraint, while potentially limiting in some applications, often drives innovative solutions in heat integration and energy efficiency.
Column Design: The mechanical design aspects of DWCs require particular attention to ensure robust operation. Recent advances in fabrication techniques, as reported by Staak (2014), have significantly improved the reliability of wall installations while reducing construction complexity. These developments have contributed to the growing industrial acceptance of DWC technology as a mature separation option.
Overcoming Technical Hurdles
The transition from conventional distillation to DWC technology presents several significant engineering challenges that require careful consideration during both design and implementation phases. These challenges, while substantial, have been progressively addressed through technological advancement and operational experience, leading to increasingly robust solutions for industrial applications.
A primary mechanical challenge involves ensuring uniform flow distribution across the divided sections while maintaining structural integrity. Research by Staak and Grützner (2017) demonstrates that uneven flow distribution can significantly impact separation efficiency, potentially negating the energy savings potential of DWC implementation. Their analysis of an industrial-scale extractive DWC revealed that proper mechanical design could maintain separation efficiency while achieving energy savings of 28.4% compared to conventional arrangements.
The management of pressure drop across wall sections emerges as another critical consideration. Computational fluid dynamics studies (Wang, 2013) have shown the presence of the dividing wall creates complex hydraulic interactions that must be carefully managed. Research indicates that optimal performance occurs when pressure drops remain within 10% of each other on both sides of the wall, necessitating precise mechanical design and internal configuration.
Control system implementation, historically viewed as a significant barrier to DWC adoption, has evolved considerably. Contrary to early assumptions about the necessity of advanced control strategies, industrial experiences documented by Tututi-Avila (2014) demonstrated that conventional proportional-integral (PI) control schemes can effectively maintain stable operation. Their study of a benzene-toluene-xylene separation system achieved product purity variations of less than 0.5% using standard PI controllers, challenging the perception that DWCs require complex control systems.
Heat transfer across the dividing wall represents another engineering consideration that impacts both design and operation. Research by Donahue (2019) quantifies the impact of cross-wall heat transfer, showing that while it affects energy efficiency by 2%-5%, proper wall design and material selection can minimize this effect. Their findings suggest that the benefits of reduced energy consumption significantly outweigh the minor inefficiencies introduced by cross-wall heat transfer.
From Theory to Practice: Real-World Applications
The practical implementation of DWC technology across various industries has generated compelling evidence of its benefits in real-world applications. These success stories provide valuable insights into the technology's versatility and effectiveness in different separation contexts.
A particularly noteworthy example comes from one of the largest refineries in Southeast Asia, as documented by Bhargava (2017). The implementation of a DWC for FCC naphtha splitting achieved remarkable results: energy consumption decreased by 42.17% compared to conventional distillation options, while maintaining product purities within specification. The revamped column demonstrated superior performance in separating heart-cut naphtha, reducing the overlap between heart-cut and bottom cut from 37°C to -3°C, indicating significantly improved separation efficiency.
Another significant implementation reported by Staak and Grützner (2017) was the successful development and operation of an extractive DWC. The installation proved particularly noteworthy as it was designed entirely through simulation studies without pilot plant validation, demonstrating the maturity and reliability of modern DWC design methods. The column achieved energy savings of 30% while maintaining product purities above 99%, with capital cost reductions of approximately 25% compared to conventional alternatives.
In the petrochemical sector, Li (2023) document a successful application of reactive DWC technology for the co-production of ethyl acetate and n-butyl acetate. Their implementation achieved a 20.4% reduction in total annual cost compared to traditional processes, while simultaneously improving product quality. This case demonstrates the potential for DWC technology to enhance both separation efficiency and reaction productivity in integrated processes.
These industrial implementations share common elements of success: careful attention to design fundamentals, thorough simulation studies prior to implementation, and systematic approach to control strategy development. The demonstrated reliability and performance improvements have contributed significantly to the growing acceptance of DWC technology as a mature option for process intensification in separation processes.
Innovation on the Horizon
The trajectory of DWC technology suggests continued evolution and expanding applications across the chemical processing industry. Recent technological advancements and growing environmental pressures indicate significant potential for further innovation in this field. Research developments and industrial implementations demonstrate several promising directions for future growth.
Advanced modeling capabilities have emerged as a crucial enabler for DWC optimization. Pappas (2023) details the development of multiparametric programming approaches that enable real-time optimization of DWC operations. Their research demonstrates potential additional energy savings of 10%-15% through dynamic optimization of operating parameters, suggesting substantial room for improvement even in existing installations.
The integration of DWC technology with other process intensification strategies represents another frontier of development. Yang (2023) present compelling evidence for the synergistic benefits of combining DWC with vapor recompression heat pump technology. Their analysis reveals potential energy savings of up to 43.58% compared to conventional configurations, while maintaining product purities above 99.95%. This integration exemplifies the potential for hybrid technologies to further enhance the efficiency gains achievable through DWC implementation.
Environmental considerations increasingly drive innovation in separation technology. Recent studies demonstrate that DWC implementations can reduce CO2 emissions by 30% – 40% compared to conventional distillation arrangements (Qian, 2023). This environmental benefit, coupled with economic advantages, positions DWC technology as a compelling enabler for sustainable chemical processing.
The expansion of DWC applications into new domains also presents exciting possibilities. For example, the application of DWC technology in biomass processing and renewable chemical production demonstrates potential applications beyond traditional petrochemical separations (Li, 2023). These initial studies suggest that DWC configurations could play a crucial role in developing more sustainable biorefinery processes.
Derived from both academic research and industrial experience, all results underscore the importance of a systematic approach to DWC implementation. Organizations that carefully consider these factors during planning and execution phases position themselves to realize the full potential of the technology.
Thomas Kwan | Vice President, Sustainability Research
Thomas Alan Kwan is an energy transition expert at Schneider Electric's Sustainability Research Institute. With a Ph.D. in chemical and environmental engineering, he brings a blend of academic rigor and industrial experience to the field of sustainable manufacturing and green engineering.
At Schneider Electric, he leads initiatives focused on new and emerging industrial systems, with a particular emphasis on the chemical processing sector. His work involves developing innovative solutions and practices to drive energy, environmental and economic benefits.
Previously, he was a key member of Unilever's product engineering team, where he integrated green chemistry and engineering principles for product and process development. His contributions earned him a lifetime honorary membership on the team. Kwan also has experience in environmental regulation, having worked with the U.S. EPA on Clean Water Act programs.
Through his research and collaborations, Kwan continues to explore innovative ways to reduce energy consumption, minimize waste, maximize value and improve overall process efficiency in chemical manufacturing operations.
