A new study carried out by researchers from the University of Vienna, Austria, and published in a recent issue of
PLOS ONE, sheds further light on the process and hints at associated spiritual practices.
The researchers — specialists in classical archaeology, veterinary science, forensic medicine and analytical chemistry — have been investigating a largely undisturbed purple dye workshop at Kolonna on the Greek island of Aegina.
In its cultural heyday, about 2,000 BC, Kolonna was a densely built and strongly fortified settlement that experienced a period of economic prosperity. At some point between 1,900 and 1,700 BC, purple dye production began.
The Austrian team has unearthed raw material and debris in the form of crushed murex shells, tools and facilities, including pounders, a grinding stone and a waste pit, plus the finished product — dye pigment.
Enough of the pigment remained on pottery fragments from different vessels to be analyzed by high-pressure liquid chromatography.
This revealed the banded dye-murex Hexaplex trunculus was used almost exclusively at Kolonna. It’s an unusual finding for the region, suggesting this mollusk had an overwhelming dominance in that area or that the manufacturers hadn’t heard of the evolving “double dyeing” process, which used pigments from both Hexaplex trunculus as well as Bolinus brandaris.
Note to Philaenis: Kolonna dye even now emits a slightly fishy odor when mixed with water.
The “remarkable homogeneity” of the pit sample suggests that the mollusks were hand-collected, possibly by divers.
No reliable estimate of the scale of purple dye production is possible, as there is no evidence of the frequency of emptying and refilling the waste pit. However, the ubiquitous admixture of partly trampled purple shell fragments suggests at least continuous, perhaps professional activities. A network of nearby ditches and basins, yet to be excavated, could also play a part in the process.
However, within the excavated area of the purple workshop, the team did find skeletal remains of heavily burnt infantile and juvenile piglets, kids and lambs.
Noting the complete destruction of the burnt remains of restricted age, sex, species, body part, and treatment, the team suggests the animals were used in ritual activities aimed at promoting the highly meaningful event of purple production rather than normal food consumption practices.
