Shutterstock
663a4903cea8fb2122b51b4d Shutterstock 573899908
Process Safety — Manage The Only Constant: Change
May 17, 2024
Understanding the two kinds of change, deliberate and creeping, will aid you in keeping your facility a safe place to work.
The ancient Greek philosopher Heraclitus is credited with the notion that the only constant in life is change. This wisdom reflects the reality that the world is in perpetual flux, and change is inevitable. Change can manifest itself in two ways. First, there is deliberate change, which occurs when we consciously intervene and initiate transformations. Second, there is gradual change, often referred to as creeping change, where systems or equipment slowly deteriorate over time. Recognizing and managing both deliberate and creeping change are critical for good process safety management.
This year marks the 50th anniversary of the catastrophic explosion and fire that tore through the Nypro plant in Flixborough, U.K., resulting in the tragic loss of 28 lives and leaving 89 others injured. In this devastating incident, both deliberate and creeping change played significant roles.
On June 1st, 1974, the massive blast not only destroyed the facility but also damaged homes in the neighboring village. Over the past five decades, the Flixborough disaster has been extensively documented and analyzed. Despite the passage of time, this tragedy continues to offer lessons that remain highly relevant even today.
Trish Kerin, Stay Safe columnist | Director, IChemE Safety Centre
