Figure 2. Crucial Freezer: Amperage data provided by monitor enabled detection of imminent failure.
Research activities rely on ultra-low-temperature freezers. Reliability issues with older stand-alone freezers lead to downtime and potential loss of work product — mandating more-frequent maintenance to avoid these problems. Proactively detecting issues and preventing failures would result in increased freezer uptime and could potentially extend the useful life of the units.
The ChallengesImplementing performance-based maintenance on existing systems raises issues such as cost and invasiveness. Asset-condition monitoring requires replacing analog instruments or installing new instruments to collect data. Traditionally, this work is invasive and demands a process interruption and engineering oversight. Furthermore, the new system must be commissioned for restart. This often includes inspections and leak checks as well as revalidation to return the system to service — frequently resulting in an unfavorable cost/benefit ratio.
Table 1: How Monitoring Options Compare
Factor |
Traditional |
Non-invasive Wireless |
Plant disruption |
Necessary wiring required Invasive
No Process Interruption Mininal wiring Clamp-On devices
Reliability |
Power source needed Real-time data collection
Battery operated Preprogrammed data-collection rate
Engineering |
Changes exisiting system May require engineering change management System recommissioning needed for restart
No changes to exisiting system Minimal engineering change management No system restart needed
Infrastructure |
May require new software
Interface available for integration into existing infrastructure
Cost |
$3,000--$5,000/point
$750--$1,500/point
We identified a non-invasive monitoring solution from Cypress Envirosystems (www.CypressEnvirosystems.com), San Jose, Calif., that promised a cost-effective alternative. It uses devices clamped onto existing instrumentation to collect and wirelessly transmit data to a server for trending and alarming. This method eliminates the need for process interruption for installation, minimizes engineering oversight and offers other benefits (
Table 1). However, it’s new technology and, thus, posed concerns about data integrity, wireless security and data integration into our existing infrastructure. To demonstrate proof of concept as well as to quantify potential savings, we partnered with Cypress Envirosystems to pilot the technology on some steam traps and freezers.
Impressive ResultsWe began installing units in September 2008, putting them in service in our normal operating environment. Wireless Steam Trap Monitors (WSTM) were placed on 56 traps (
Figure 1) at a cost of $42,000. The WSTM were intended to provide early indication of steam leakage or blockage, which leads to failure. Data were collected on a “blue box” server for trending analysis.
