There's nothing more frustrating than chatting with a co-worker, client or reader who has sent you an e-mail with information regarding time-sensitive issues that you can't find in your e-mail inbox. After a fruitless search, you decide to wade through the mounds of messages in your spam folder and sure enough, said e-mail is hanging out with all the unsavory correspondence. It's the same way with e-newsletters. Chemical Processing sends out its e-newsletters on a regular schedule. If you're not receiving them as you should, help is on the way.
To assist you in moving those e-mails on the right side of the tracks, we've gathered tips from around the web for how you can "whitelist" (ensure e-mail delivery) ChemicalProcessing.com e-blasts for Outlook 2003, Yahoo, and Gmail.
Outlook 2003
Add ChemicalProcessing.com's "From" address — we use [email protected] for most newsletters; however, we also use [email protected] to deliver surveys and other magazine-related updates — to your Safe Senders list:
1. On the Tools menu, click Options.
2. On the Preferences tab, click Junk E-mail.
3. On the Safe Senders tab, click Add.
4. In the Add address, put [email protected] or [email protected]
5. Click OK.
Yahoo
New Subscribers:
You'll want to set up a filter to redirect our newsletters into your e-mail inbox:
1. Open your mailbox and click on Mail Options (upper right hand corner).
2. Select Filters.
3. Click Add link on the Filters page.
4. Update the "From header" rule with these two pieces of information: "contains" and [email protected]. Repeat the step with "contains" and [email protected].
5. Click the Choose Folder pull down menu and select inbox.
6. Pick the Add Filter button.
Existing Subscribers:
If any of ChemicalProcessing.com's newsletters or e-blasts are getting stuck in your Yahoo Bulk Folder, please open the e-mail and click the "Not Spam" button. You can also check to see if the newsletter's email address is in your "Blocked Addresses" list. If you see [email protected] or [email protected] on this list, select it and click the Remove Block button. The last step of the process is to set up a filter as shown above.
Gmail
New Subscribers
Please add our "From" address, [email protected] or [email protected], to your Gmail Contacts List:
1. Click Contacts along the left side of any Gmail page.
2. Click Add Contact.
3. Copy and paste our "From" address, [email protected] or [email protected] into the primary e-mail address dialog box.
4. Click Save.
How to check if our newsletter is in the "spam" folder:
1. Click "Spam" along the left side of any Gmail page.
2. Checkmark the box next to our newsletter.
3. Click on the Not Spam button along the top.
AOL
New Subscribers
Please add our "From address" [email protected] or [email protected] to your AOL address book:
1. Click the Mail menu and select Address Book.
2. Once the Address Book window to pops up, click the Add button.
3. Paste [email protected] into the Other E-Mail field. Repeat the process for [email protected]
4. Make our From address the "Primary E-Mail" address by checking the associated check box.
5. Click the Save button.
If our newsletter is in your AOL Spam Folder, please open the email(s) and click the This Is Not Spam button. Next, please add [email protected] or [email protected] into your Address Book as described above.
Hotmail
New Subscribers
You'll want to add our From address, [email protected] or [email protected], to your Hotmail Safe List:
1. Open your mailbox and click Options
2. Click the Junk E-Mail Protection link
3. Select the Safe List link
4. Copy and paste [email protected] or [email protected] into the dialog box "Type an address or domain".
5. Click the Add button next to the dialog box.
If our newsletter is in your Junk E-Mail Folder, open the newsletter and click the Not Junk button. Check to see if our email address is in your Blocked Senders list. If you see [email protected] or [email protected] appears on this list, select it and click the Remove button. If you have not done so, add [email protected] or [email protected] into your Safe List as outlined above.
Traci Purdum is Chemical Processing's
senior digital editor. She will never knowingly send you junk e-mail. You can contact her at [email protected].
