Gaskets are ubiquitous components in a processing plant. Every flange, equipment joint and connection point will have some form of gasket to prevent fluids from compromising (i.e., leaking from) a process system. However, effective sealing can pose challenges. A new form of polytetrafluoroethylene (PTFE) gasket, Gylon Epix, already has successfully addressed a number of persistent problems at plants.
The gasket, which is available in 3⁄32-in.-thick, 60-in. × 60-in. sheets, features a raised hexagonal pattern (Figure 1). It exhibits enhanced compressibility over both 1⁄16-in. and 1⁄8-in. traditional gaskets, seals easily when compressed by flanges and maintains assembled bolt torque better than comparable 1⁄8-in. PTFE gasket materials.
Successes
Trials at three early adopters of the new material underscore its value.
Fatty acid production. A German manufacturer of oleo-based chemicals, including fatty acids, glycerin, fatty alcohols and fatty esters used in consumer and personal health products, was experiencing problems sealing a 29.3-in. (745-mm) outside-diameter spiral heat exchanger. A gasket located atop the heat exchanger was exposed to polysaturated fatty acid and coolant at a continuous temperature of 428°F (220°C) and pressure of 87 psig (6 bar). J-type clamp bolts fasten the lid to the heat exchanger. Spiral heat exchangers present challenges because the gasket must seal across the entire face of the lid, requiring a gasket that will efficiently transmit the force from the bolts across its entire surface.
The traditional PTFE sheet gasket was allowing leakage across the exchanger’s spiral passes, decreasing efficiency. The gasket exhibited cuts from the spiral separation bars and required frequent changes that disrupted manufacturing and decreased plant productivity.
