Flow Pattern
Figure 1. Solute is flowing from left to right in a square and skinny duct. The square case arrives with a gentler buildup (with more mass to the left), while the skinny case arrives with a more abrupt, sharper front. Source: Manuchehr Aminian, Francesca Bernardi, Roberto Camassa, Dan Harris and Richard McLaughlin, UNC
Results show that precision elliptical pipes, which may be difficult and expensive to manufacture, deliver fluid with calculated precision, but so too, given the right aspect ratio, do cheaper and easier-to-make rectangular ones. Rectangular ducts also stretch solute much less than ellipses, which can be critical when delivering more highly concentrated substances.
This new work can be used to optimize microfluidic devices for any particular goal. Tuning concentration gradients to improve output response could potentially help fine-tune reactions as well.
“We have been thinking about concentration-gradient-controlled chemical reactions, and in particular, how merging different solute streams from different shaped ducts could assist the careful tuning of concentrations at the merging location where a reaction could take place. This could be a potentially interesting application for manufacturing chemical compounds,” explains McLaughlin.
The team already is assessing more-complex geometries with many preliminary results theoretically and computationally obtained for various complex geometries. “We are starting to implement an experimental study of those domains,” says McLaughlin.
The researchers say they would like to hear from anyone that has suggestions for applications or how to apply their findings in a practical device.
