WIRELESS pH ANALYZER
Figure 1. Unit monitors seal fluid to safeguard against corrosion of vacuum pump.
Three alternatives could prevent the problem: using exotic materials of construction, installing an intermediate tank to capture vapor (not possible in the available space), or analyzing the seal fluid to detect leaks before they caused damage. Opting for a simple analysis system was the proverbial "no-brainer."
Leak detection can be performed using either pH or conductivity analysis. The choice depends on the process. For pH to be used, a small amount of contaminant must cause a measurable change in the pH of the process; for conductivity to be suitable, the contaminant must significantly alter the conductivity. Conductivity can detect leaks of acids, bases or even salts but requires stable process conductivity for best results.
The chemicals to be monitored by FujiFilm affected pH. So, the plant installed a pH analyzer in the vacuum pump seal loop (Figure 1). It chose a wireless unit to obviate power and output wiring. Because a wireless gateway already was in place for other process control applications, implementing the analyzer was easy. It was incorporated into a self-organizing network that allows each device to function as a data repeater. Thus, if any pathway becomes interrupted, data automatically travels via an alternative pathway, assuring uptime. The pH monitoring system cost less than $3,500 to implement and was up and running in two days.
Since the plant installed the pH analyzer in June 2011, it hasn't suffered any corrosion-related pump failures.
In the FujiFilm application, the normal pH of the seal fluid (water) is approximately 7; at that point, corrosion is minimized. To protect the vacuum pump seal integrity, when the analyzer finds the pH has dropped below 3, the process is stopped and the system is flushed to clear out the acid and return the process pH to 7.
